ok guys, I've changed my combo (again) and will be assembling the car this month
gofastr
LOSE2ME
my combo will end up as follows:
te-63-1
3500 9/11
72LB'ers
duttwieler front mount
champion irons
champion intake
62mm TB
3"THDP
reds double pumpers
chips by TESTA (who do you guys recommend for the 72's and te63?
built trans
I think I will be happier with the combo. should RIP A$$!! how do you think my car will hook with this stuff and my hrparts upper and lowers, HD springs with bags, billstiens, ATR rear sway, and some nitto 275 60 15 dr's?
(god, am I a pain in the butt.)
don't waste your time trying to race with drag radials...you will just be frustrated.....get some slicks (not DOT tires, real slicks)
best "chip" is the MaxEffort
sounds very stout but I don't think the DR's stand a chance unless you plan to run at 18-20psi tire pressure all the time...
I'd run alchy injection on the street though for full time power.... and then 116+ at the track with slicks.
Your car should be able to run some 10's easily if you get the tune down right. Bob Bailey is a good chip tuner also......
-GNX7
