Since you just shotgunned the pump gears, MAKE SURE you can turn the shaft by hand. If your pump is locked up and it's forced to 'self clearance', you're in big big trouble!
If it turns and you bust it off, see oil pressure and everything looks cool... I'd at least change the filter with a quality, non fram, unit.
As a general rule I always change the oil after I open up an engine.
