john keskes
- Dec 29, 2012
was the front crank seal was blown out with mine
Glad you found that missing boltYes sure is that car. And it was a missing bolt in the timing cover behind the harmonic balancer
Congratulation on your first GN
Like myself many years ago, I read a lot and ask many, many questions
Start creating a library folder and download all that pertains to the GN, if you find info on the web, convert them into PDF files since sometimes web info disappear, or if the info changes to something different then what you want it to be.
Here are some info sites:
http://www.gnttype.org/maint/basics.html
http://www.vortexbuicks-etc.com/index.html
http://www.gnttype.org/techarea/electrical/wiring.html
http://www.ihadav8.com/forum/index.php - This is another great Buick site with many knowledgeable members
http://www.docdatabase.net/more-1986-87-buick-g-body-340514.html - This PDF only runs in Window IE, all other can use this site, lower right side you can open and run the PDF files.
