OFFICIAL 2014 TSM RULES DISCUSSION
I like the rules as is. Based on what little I've seen from my car I think the weight for a stage motor is probably not far off.
If i had to propose anything, I would like to see 4 bolt turbine housings allowed. 68mm turbines could stay, just with a 4 bolt housing. It just allows me to bolt on a bigger turbo easier for local racing.
I would like to see:
-4 bolts allowed
-exhaust not needed
-allow wastegate to be open air (like ths does)
-no tech for 9.50 and slower
Sent from my SCH-I545 using TurboBuick Mobile mobile app
Other GM body styles as long as they fit the rules of stock suspension, turbo.....
I say:
71 turbo
3250 iron
+ 100 aluminum
+ 100 stage block
No exhaust req'd
Open wg allowed
Since they would have v-band downpipes, just pull the downpipe and measure. Might have to pull the turbine housing and use a plug. Or, it might be possible to do it via part number like we have now.
Didnt know there was a limitation on the turbine side
