Hey guys, I've got a question about whether or not there needs to be an (x) distance between alcohol injection nozzles and an IAT (intake air temperature) sensor. I'm curious as to whether or not there needs to be a measured amount of distance and time for the alcohol to flash and freeze the charge for an IAT sensor to accurately see it. Anybody have any data on this? On my old plumbing setup, I had a cast aluminum throttle body inlet adaptor piece that bolted in front of the throttle body that housed both the injection nozzles and the IAT sensor. When datalogging while boosting, I would see the IAT's shoot up but then rapidly drop the instant I went to decel. On the current setup, I've got the injection nozzles plumbed into the charge pipe about 3.5-4" before the IAT sensor that's sitting just in front of the throttle body. Check the picture below for a closer look. Am I over-thinking this or would it be prudent for the purposes of air temp/fuel corrections and accurate datalogging to move the nozzles further upstream?
Btw, glad to see some of you Turbobuick piston-head alcohol guys again on here. Haven't been on the forum in awhile. My red Mazda rotary has been parked for awhile while other stuff was goin' on. I just recently removed the ridiculously inefficient stock top-mounted intercooler and converted it to hot-air. I'm trying an experiment to see how efficacious alcohol in the charge acts as a "chemical intercooler" as it were on this setup with the heavy alcohol to gasoline ratio I use.
B
B
