I just finished replacing the rear suspension in my Buick. It went from South Side Machine lift bars (don't ask, they were in the car when I bought it) and an ATR swaybar to UMI Rotojoint/Poly LCAs and no sway bar (Hellwig 55809 on order). The only constants are the single adjustable UCAs (rod ends on the frame side, factory rubber n the diff). There was no elongation in any of the bolt holes and no cracks in the torque boxes.
And believe it or not the car has developed a horrible clunking (almost crunching chatter) sound under braking at low speeds and over uneven pavement. You can feel it in the floor boards.
The UMI LCAs were torqued to spec under a loaded suspension (front to rear) and the UCAs were torqued as close to ride height as possible (springs had to be left out for the tools to fit). The only notable change made (other than dumping the SSM bars) was that I shortened the UCAs by 1/4" (11" total length CL to CL) in order to adjust the pinion angle (currently set at -2*).
I am going to "nut and bolt" the suspension (again) to validate my work. Also, it should be noted that the 4" exhaust is hitting the axle tube under compression... I had my wife jump up and down in the trunk to ID this problem; much to her embarrassment.
Any insight or direction would be appreciated.
