boostmaster
- Aug 20, 2001
As the title stated. I have no 2nd gear it shifts strait from 1st to 3rd the to OD. I don't even have 2nd gear engine braking. I see in the ATSG manual that 2nd shares the forward and overrun clutches with 1st and 3rd when applied and I have both those gears so I'm thinking it might be that the band is burnt and slipping. The trans flares when I try to test engine braking in 2nd. I took pressure readings and they are as follows.
TV Min / TV Max
P 65 - 210
R140 - 260
N 65 - 210
OD 65 - 210
D 65 - 210
2 180 - 220
1 180 - 220
Seeing that I have adequate pressure in all gears am I right in assuming that it might be the band? Also I took the pan off to check the governor and found a small little piece of metal in the pan. I have attached a photo can someone tell me what it is. Maybe nothing but????
TV Min / TV Max
P 65 - 210
R140 - 260
N 65 - 210
OD 65 - 210
D 65 - 210
2 180 - 220
1 180 - 220
