Im curious with this new setup how good the boost control is.
I know with a lesser boost controller that it being is a reverse
direction i have seen over boost issues on launch.
Look nice Ted.
Why? What difference would it make? Mine is set up similar to that I believe if I can remember right.You're not necking it down right at/after the turbo are you?
If you absolutely have to neck down the pipe size, it should be carried out with a long taper section. Same goes for when you need to neck up in pipe size. A quick neck down like that will cause a restriction to gas flow acting as though the pipe that you just necked down to is actually smaller than it really is. Of course, it will work, but not as efficiently as it could with the proper taper.Why? What difference would it make? Mine is set up similar to that I believe if I can remember right.
To put it simply, if you're trying to impress people that know better, you don't neck down, and if you do, at least do it over a long taper section.
When I mounted my wastegate in a similiar location I lost boost control. Rather than being able to hold 7#, it wouldn't go below 17#. The exhaust wanted to continue through the turbine rather than making it's way to the gate. It doesn't make sense, with the pressure the hot side sees, the gate should still flow enough to control to boost but it was a definate difference just from the location of the gate.
my point exactly,from what i have found hte ex needs to actually run a path as though it were flowing into the gate rather than having to make an abrupt turn into the pipe in an opposing direction.When I mounted my wastegate in a similiar location I lost boost control. Rather than being able to hold 7#, it wouldn't go below 17#. The exhaust wanted to continue through the turbine rather than making it's way to the gate. It doesn't make sense, with the pressure the hot side sees, the gate should still flow enough to control to boost but it was a definate difference just from the location of the gate.
In essence you're creating an anti-reversion valve at the exit of the turbo. Except the valve is backwards.The exducer diameter of the turbine wheel is less than 4". What's being necked down?? I have already thought about what you state here, and I feel this will not be a issue (slow us down) that's why I am making the call. Maybe I'm wrong or maybe I'm right. We'll find out. If I'm wrong, not a hard fix right?
Don't most people "Neck down" the 3.5" outlet to 3" on the compressor side?
