New Starter Issues
TTA1326
I just put a mini starter from the other Buick site on my car. I turned it over with the module disconnected to listen to it. I can hear the starter slow down on what I think are compression strokes and the immediately return to normal speed. So it has an alternating fast\slow\fast\slow cycle that is audible.
I pushed the starter nose out into the flywheel to check the gap and I think I could stick 5 or 6 paper clips in there easily. It also appears that the starter is only contacting about 1/4 of the way on the flywheel teeth. Is this entirely to far? I put a full width 1/32" shim in it for grins and it makes the starter sound like it doesn't slow down as much, but of course it doesn't help the engagement issue any.
Do I need to shim this sucker to roll it toward the flywheel or get another starter? This is the stock never been out of the car TTA block.
Check the connections on the the starter and battery. Is the battery strong? Try putting a battery charger on it and crank it over.
