NEW IAC Berrel Auto?
Originally posted by norbs
Bruce, can you post a copy of the stock timing map somehow?
Form the 87 Recall.bin:
LV8
32 48 64 80 96 112 128 144 160 176 192 208 224 240 256
RPM 200 rpm steps from 400-2400, then 400 rpm steps.
22.9 22.9 22.9 22.9 22.9 22.9 22.9 23.9 23.9 23.9 23.9 23.9 23.9 23.9 23.9
23.9 23.9 23.9 26.0 26.0 26.0 25.0 25.0 25.0 22.9 22.9 22.9 22.9 22.9 22.9
23.9 23.9 23.9 26.0 27.1 27.1 25.0 25.0 25.0 22.9 22.9 22.9 22.9 22.9 22.9
28.1 29.9 29.9 29.9 28.1 26.0 23.9 22.9 22.9 21.1 19.0 19.0 19.0 19.0 19.0
29.9 29.9 29.9 32.0 29.9 26.0 22.1 20.0 20.0 20.0 17.9 17.9 17.9 17.9 17.9
35.9 43.9 38.0 38.0 34.1 28.1 22.1 20.0 20.0 20.0 17.9 17.9 17.9 17.9 17.9
38.0 46.1 43.9 38.0 34.1 32.0 23.9 22.1 22.1 20.0 20.0 20.0 20.0 20.0 20.0
38.0 41.8 41.8 41.8 40.1 35.9 28.1 23.9 22.1 20.0 20.0 20.0 20.0 20.0 20.0
38.0 41.8 43.9 43.9 40.1 35.9 28.1 26.0 26.0 23.9 23.9 20.0 20.0 20.0 20.0
40.1 41.8 43.9 46.1 41.8 38.0 29.9 28.1 26.0 23.9 22.1 22.1 20.0 20.0 20.0
40.1 43.9 48.2 41.8 35.9 32.0 28.1 28.1 28.1 26.0 23.9 22.1 22.1 22.1 22.1
43.9 43.9 41.8 40.1 34.1 32.0 28.1 26.0 26.0 26.0 26.0 26.0 26.0 26.0 26.0
43.9 43.9 41.8 40.1 35.9 34.1 29.9 28.1 23.9 22.1 22.1 22.1 22.1 22.1 22.1
46.1 46.1 43.9 43.9 40.1 38.0 34.1 32.0 28.1 27.1 25.0 23.2 22.1 22.1 22.1
49.9 49.9 49.9 48.2 43.9 40.1 34.1 29.9 28.1 27.1 25.0 23.9 22.1 22.1 22.1
49.9 49.9 49.9 48.2 43.9 40.1 34.1 29.9 26.0 23.9 23.9 22.1 22.1 22.1 22.1
49.9 49.9 49.9 48.2 43.9 40.1 34.1 29.9 28.1 26.0 23.9 22.1 22.1 22.1 22.1
Gotta remember thou, this is for an EGR, and stock exhaust system so at light loads, there's too much timing for a none EGR application.
While you didn't ask, here's what I consider a good starting place for a TR, note, this is all for N/A mode ie 100 and less K/Pa. To get *real* numbers out of the entries, divide by 3 (actually x by 90/256)
LMainSa:
;Map: 20 25 30 35 40 45 50 55 60 65 70 75 80 85 90 95 100 ;Rpm:
FCB 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68 ; 400
FCB 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68 ; 600
FCB 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68, 68 ; 800
FCB 68, 68, 68, 68, 87, 87, 90, 96, 96, 87, 84, 81, 81, 78, 78, 78, 78 ; 1000
FCB 68, 68, 68, 99, 99, 99, 99, 99, 99, 93, 90, 84, 84, 84, 84, 84, 84 ; 1200
FCB 68, 68, 68, 99, 99,102,109,112,112, 99, 93, 90, 87, 87, 87, 87, 87 ; 1400
FCB 68, 68, 68,112,112,112,115,118,118,118,112, 96, 90, 87, 87, 87, 87 ; 1600
FCB 68, 68, 68,112,112,112,115,118,118,118,112,106, 99, 96, 96, 96, 96 ; 1800
FCB 68, 68, 68,112,112,112,115,118,118,118,112,106,103, 99, 99, 99, 99 ; 2000
FCB 68, 68, 68,112,112,112,115,115,115,115,112,109,106,103, 99, 99, 99 ; 2200
FCB 68, 68, 68,112,112,112,112,112,112,112,112,109,106,103, 99, 99, 99 ; 2400
FCB 68, 68, 68,112, 97,112,112,112,112,112,112,106,103, 99, 99, 99, 99 ; 2800
FCB 68, 68, 68, 68, 97,109,109,109,109,109,109,103, 99, 99, 99, 99, 99 ; 3200
FCB 68, 68, 68, 68, 68, 77, 99, 99,106,106,106, 99, 99, 99, 99, 99, 99 ; 3600
FCB 68, 68, 68, 68, 68, 68, 99, 99,103,103,103, 99, 99, 99, 99, 99, 99 ; 4000
FCB 68, 68, 68, 68, 68, 68, 99, 99,103,103,103, 99, 99, 99, 99, 99, 99 ; 4400
FCB 68, 68, 68, 68, 68, 68, 99, 99, 99, 99, 99, 99, 99, 99, 99, 99, 99 ; 4800
Thanks Bruce, timing did not help. I am switching back to the stock iac and see if the car runs better. I just can't get the iac steps low enough on this one.
norbs, did you try closing the IAC down with an IAC tester. I have seen IACs in general hang up and the ECU thinks it is closed but it is not. I honestly did not test one on a Gen 7 and have no plans on doing so. I am not familiar with how they control the IAC. This IAC functions fine with a FAST system and as bruce stated functions with the stock setup. One would think that DFI is using similar IAC strategy as GM but who knows. It is simply a controlled vacuum leak. If I were you I would try blocking off the air to the IAC and see how the car idles. You might have another problem going on here.
For the lack of any other way to deal with it, if you want, send it to me, and I'll run it on my ecm bench to see if it's acting the way it should.
I have found out that i have a problem with the IAC hanging sometimes, were these iac's GM orginal in the kit or aftermarket replacements?
