or it has bad gas I just put a bottle of stabil in it to see what that does I'm sure it's done turned to corn syrup
Why are you trying to tune the car to run on bad gas?
So big boy
Get yourself a known, good MAF and start there.
Where do you get a known good MAF (stock style)? - Who knows. But you can always give O'Reilly's money for one that is marginal and at least see if it cleans things up
See what happens.
Go to Vortexbuick for tips on adjusting the TPS - but I'm skeptical that's it.
If you still have a problem, buy yourself a decent set of 50-60 lb. injectors - that's not wasted money if you're running stockers
That should keep you busy for a minute or two
Now why would you steer him to a POS MAF from O'reilly's ... and he should check over the basics before he just throws parts at it... like checking plugs / wires / seeing how much rust is built up on the coil towers where the plug wires attach .. vacuum leaks from dry hoses ... GOOD FUEL with good fuel pressure ... start with basics
He stated he checked his hoses. He also stated his gas is probably shit, although I didn't comment on the Stabil scheme.
I let that slide.
I should have told him to manually drive the fuel pump and get that out.
But it sounds like the quality or quantity of his fuel is not his issue. He states he smells plenty of gas.
It starts and runs - albeit like a wounded dog.
I'll say it one more time,unplug the MAF and see if it runs somewhat better.Normally if it's bad enough it will run better with it unpluged.My first and third GN's I bought were bought cheap because of a bad MAF and would hardly run,unpluged the MAF and actually drove one home when I bought it.It is a easy check without a scan tool.Lol I'm not gonna sell it but I did get a chance to get some quality car time in this morning, combed over the whole motor making sure all vacuum lines were hooked up and nothing no sensor was unplugged or anything like that, I got it to actually start could keep it running as long as i kept giving it some gas, but it smoked like a freight train and smelled like it was straight gas, so I've come up with three things that I think it could be, the MAF, the TPS sensor or it has bad gas I just put a bottle of stabil in it to see what that does I'm sure it's done turned to corn syrup
why would i be kidding?
well i cant figure nothing out ive replaced the coil packs with acdelco units and new plugs and wires replaced cam and crank sensor, so i decided to track down the 2 previous owners of the car and talk to them the original said the computer was bad when he sold it to the man i got it from (would've been nice to know) and ive decided to go with a holley efi unit being that i live about 20mins from there head quarters and know several people that work there i am able to get a discount on it....thanks for the help and ill be doing a write up on the ecu swap process i have a good friend of mine that runs it on his ls swapped 67 camaro and he loves it!!!
You're kidding right?
