I'm finally taking the dive into methanol. What do you guys do for emissions time? Do you just keep it off and make sure the person testing the car on the dyno doesn't boost it up. Or should I change the chip and turn the boost down to stock levels? I do have a high flow cat so maybe I won't need to do anything. I am pretty sure the chip that will be made won't pass. What do you think. Also, I have a high boost actuator by itself and was wondering if that is sufficient. I've read about actuator binding and was thinking about a rjc controller. Thanks, Tim
