Bad or corroded pressure switch? Try to jump switch?Well my month old ACDelco compressor stopped working tonight, the clutch will not engage. The fans run when the AC is on and pressure is right where is should be.
I am so tired of this crap......
Did you gThe modine looks exactly like the spectra one I got through Amazon.
It fit with the stock brackets and it looks like the lines will fit without much fuss.
Did you or Chuck get your AC hooked up? How's the fitment of that condenser?The modine looks exactly like the spectra one I got through Amazon.
Did you g
I have not yet. I needed to get the car together for a get together next weekend so I just threw the compressor bypass pulley back on.Did you g
I ruined a couple sets of the extensions trying to get them to fit the repro lines and to make matters worse found a crack in the brand new lines. To credit Highway Stars they promptly refunded my $$. Reused my original lines which actually looked fine. Pulled a vacuum on each individual item before assembling so I didn't have to figure out what if anything was leaking if I just assembled. Lot more work but worth it to me. Just pulled a vacuum and let it sit overnight.
Everything is assembled (and the extension fit just fine into my original compressor line.) pulled vacuum on entire system for an hour. Charged it using the gas style, valve up connected to high and low valves vs using liquid valve down on can. Once pressure equalized with the can I jumped out the low pressure switch so the compressor would run and started the car. Used a scale to calculate the lbs going in. Took a while but worked out perfect and so far so good. Nice and cool. Used R-12 that we found on ebay.View attachment 257554
Mark, did your new compressor have 2 sizes of ports?
The extensions appear to be a good fit on the old lines. They are in what appears to be, good shape, so I'll clean them up, and reuse.
How did you block the lines for the vac test?
Glad you got it done and working.
BTW, my original dryer was painted. Was yours? {I noticed it's now natural finish.}
I bought a kit some years ago from someone called Savanna auto air. $250 for everything except freon.
Get the green o-rings for R-134a.
I used a white orfice tube but the ford blue is supposed to be better.
And if you go back with R-134 forget what everyone says about charging it to 80% of the R-12 charge. Put some gauges on it and charge it by a PT chart for the outside tmp at the time.
Do you happen to have th part number for the ford orfice?
