3.8L V-8 eater
- Jul 22, 2006
Have you checked your fuel pressure with vac line off the regulator?
True.Should be a code on the scanmaster if this is the case
I stand corrected.True.
No wonder it won't run right. Try it at 43 line off.Fuel pressure steady at 48#
Reset fuel pressure to 42#... Runs ok idles like crap....won't even stay running.....have had this problem whenever intake temp reaches 165 or higher ever since engine was rebuilt...mechanic said he was stumped....what to try next
Good point.Do you have dual fans? Is your cooling fan blowing across your air filter? What kind of intake setup do you have? Possible fan wash issue.. You said it runs like crap when it warms up, exactly when the fan turns on... I've had this problem before and ran like crap, couldn't go wot. Reinstalled my cold air kit with the filter behind the bumper and problem solved.
Sorry I haven't responded in a few days, I have been in the hospital since early Monday morning after getting sick Sunday. Supposed uti....prostatitis. As soon as I am able, I will post plug results. View attachment 215825
