Toby_Goodmk
Test Fit officianto
- Dec 9, 2011
Take a look at the pictures. It seems I have #6 not completing combustion. I was wanting someone to help me diagnose if this is a fuel issue, or a spark issue. It appears there is some carbon of some sort on the porcelain which makes me think the plug is arcing. The others are suspect as well as they are a little wet on the threads, however this may be due to me not driving much and most of the reading on these plugs are from idling.
My condition that brought this about was a miss and low power through mid throttle.
**#6 cylinder is the clean one.
**#3 plug is burning, so it tells me because of waste spark that coil seems to be operating ok???
Any means to testing and making sure?
These are 60lb Precision siemens, with the TR6 module
