W WINDMILL New Member Joined May 24, 2001 Sep 8, 2010 #1 ok i went from a 200r4 trans to a 350,,,,ok if my chip has higher timing in 1st and 2nd and lower in 3rd and 4th... on the 350 trans what timing does it have, or i need to change chip.. help needed.
N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Sep 9, 2010 #2 I think you will be fine the way it is what chip you using?
N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Sep 10, 2010 #3 The trans has no gear pressure switches so it will just use the same timing for all gears.
W WINDMILL New Member Joined May 24, 2001 Sep 10, 2010 #4 well what if it was like 25 in 1st and 2nd and 22 in 3rd and 4th?
E Eric Stage I TurboTweak Guy Joined May 25, 2001 Sep 10, 2010 #5 It depends on the chip. My chips use MPH to determine gear for timing and fueling, not the tranny gear switches. Other chips may use gear switches.
W WINDMILL New Member Joined May 24, 2001 Sep 11, 2010 #6 well my spedo is not hooked up, because this 350 trans is plug off, hey thanks for the info tho..
E Eric Stage I TurboTweak Guy Joined May 25, 2001 Sep 11, 2010 #7 Depending on the chip, having the MPH unhooked might not work well either.
