xrunner123
- Oct 2, 2002
It's not the GN but my 2002 Jeep Liberty.
I was driving off from a light and the trans started to slip real bad. I pulled over and the check engine light went on.
Now none of the gears work at all- car does not move.
The codes were P0732 and P0876.
P0876....Transmission Fluid Pressure Sensor/Switch "D" Circuit Range/Performance
P0732 JEEP - Gear Ratio Error In Second Gear
Is this a blown trans or just a sensor replacement?
I am stuck in the parking lot. Do I get towed to a trans place or will replacing the switch in the parking lot work?
Thanks\
Need HELP ASAP!!
Thanks\
Need HELP ASAP!!
