dr.frankenstein: because i want to stick with NA engine sins the car will have a nascar theme/look therefor i want to keep the carburetor
thanks for the tip about the pistons
I love the rough sound from the na v6 its not that smooth rumble like the v8 is more like a snarling
warwagon: why exactly Federal Mogul pistons? summit racing also has kieth black and can i use the regular once or do i need the Hypereutectic Pistons??
was is the differance between the engine i have and the stage 1 and 2? im lookin at summit racing and checking out head gaskets the only copper gaskets i see are for stage 1 where can i get copper gaskets for MY engine? and im assuming i need stronger gaskets the stock once
so standard type pistons are good enough i assume its the same with the rods?
ill stick to the steel shim gasket then
where can i get those rods? ive been looking at H beam rods from scat also
anywhere i can buy new rods? i preffer to get everything new that way i know what i get with used once i dont know how theyre been used or abused i dont really wanna experience a rod snapping
