....for what it will cost to cut the crank you have I would try to find a crank already cut at .010/.010 and go
have to remember that the NA V6 engine had a 2bbl carb and was rated at 110 HP.
an intercooled turbo Buick engine in stock trim produces about 290bhp.
both NA and turbo stock cranks were the same "229" castings. NA cranks had rolled fillets on the mains only. Turbo cranks had rolled fillets for BOTH the main and the rod journals.
Remanufactured cranks may have had many or most of the rolled fillets in the mains and rods repaired one or more times and it still qualifies as a "good service part."
I would be very picky here. You have to confirm with the shop what the cost is to prep that NA crank. At 20/20, it is done for any future work.
My suggestion is to pause for a moment. Search for a turbo crank that has been turned no more than 0.010" and has not had any rebuilt journals. What is that crank going to cost you compared to the machining cost of that NA crank? If you're within a hundred bucks, I would go for the turbo crank.
Will the NA crank work on a street car at stock or near stock power/boost levels. Probably not an issue. stock stuff is maxed out at 360bhp.
Again, cost is the key driver here. Why spend potentially more $$$ to grind and polish a NA crank at 20/20 when you might find a ready to go turbo crank for similar cost?
Billet main caps on #2 and #3 are not needed at stock or near stock levels. once the combination starts hitting mid-400 to 500bhp then billet caps are most necessary plus a girdle as the main webbing is the weak spot on any of the stock blocks.
"EDIT ADDED INFO: besides a turbo Buick stock crank, the stock crank in the '89 turbo trans am will work also, if you can find one."
Nick Micale noted the same concepts in this old thread. old thread yes, but the information does not change. there is a ton of info to be learned by just searching the archives here.
http://www.turbobuick.com/threads/rolled-fillet-crank.45294/
