This is just a "for your information" on my project of putting a front mount intercooler on what is basically a stock 87 GN. Now I know I did not "need" a front mount (I do not need alot of things I have) but I am sure I will grow into it as time goes by.
First off I have stock turbo,stock type green stripe injectors,stock heads etc. I do have a big-mouth cold air system,hooker exhausts,thrasher street chip and the car is running pretty well. I have done all the little things like a hotwired 307 pump,blocked off throttle body water etc, but all in all pretty stock.
I installed a PTE front mount that I bought when they were on sale. After driving it around for several weeks and going to the drag strip a few times here are my results:
As far as overheating on the highway on long trips goes- no overheating at all and in fact my scanmaster showed it was running COOLER at about 155-159. Before the FM I was running around 160-165. I attribute this to the fact that I moved my transmission cooler from in front of the radiator to behind the passenger air dam. I am running a 160 degree thermostat and I have mostly distilled water(there is still some anti freeze in there) and 1 bottle of water- wetter in the stock radiator. I recently had the radiator rodded out ,it definitely needed it. I also have the fan sealed up to the radiator with air conditioner foam. and I cut around the stock baffles so I could continue to use them on the front mount. I did tie wrap the edges and corners so that they were as snug as could be.
Now that was on a 9 hour trip with the ac on on the highway. At around town speeds including sitting in stopped traffic with ac on in 91 degree temps I recorded readings of 171 degrees max. I do have the fan wired so I can turn the hi-speed fan on and I have it on when I am stopped in traffic but have not used it on the highway. Without the fan turned on my max readings are 179-185. Not too bad at all.
At the 1/8 mile track I go to I have noticed my times are more consistant and my speed is slightly higher.
before best was 8.597 at 80.583 with most runs in the 8.63 range at high 79 mph. this was in mid 60 degree temperatures.
after the install of front mount best was 8.524 at 81.7 mph with most runs in the 8.5 range and best speed at 82.754. Now this was in 85 -90 degree temperatures.
These runs were all made on street tires with 93 octane gas with a little zylene at about 20 pounds boost.
I believe that if I could have run in the same temperature range as my first runs the times and mph would have been higher. As it is I am happy.
As for driveability I have noticed a slight slowing in the spooling of the turbo. Have also noticed a power increase when going WOT at about 55-65 mph. It really takes off now.
This info is the results I obtained from the last few weeks. I just wanted to share in case anyone out there was needing the info. Hope someone can use it.
good luck guys!
good luck guys!
