I'm not going to get into a debate with those who think an electric crankcase evacuation system is not or should not be needed b/c I have my own reasons for wanting one: To minimize any oil leaks....and they work but instead of running it off a hobbs switch I wanted it to run all the time.
The electric GM smog pumps that people have used to evacuate the crankcase work great but they do NOT like to be run all the time. I discovered this for myself when the electric motor failed after a few days due to heat which caused some of the plastic parts inside the motor to melt. I needed a 12v motor that is designed to run continuously and decided a heater fan motor may work.
I found several on ebay for around $25-$30 and bought a few with different housings giving me several options to make an adapter to mount the motors to the pump housing.
Here are pics of what I came up with and it has been working great for a week so far. Only time will tell how long it will actually last but this motor is designed to run continuously so I have high hopes.
The below pic shows the fan motor on top of the adapter I made then the fan portion of the pump housing bolted to the adapter.
Both v-covers are sealed off except each has a hose that runs to a canister to separate any "liquid". Then a valve cover breather is mounted on top and a hose runs to the vacuum pump. I discovered that the breather had a foam element in it and this quickly got saturated with moisture so I removed the foam and it's been working great so far.
Before, with both valve covers vented to atmoshere, I always got a dribble of oil out of the v-cover fill hole just driving around town for 5 minutes. This evac system creates enough vac that I get absolutely NO leaks even under boosted runs.
The next thing to do is move the canister under the bumper b/c this draws a LOT of moister from the crankcase and I will probably need to drain it often. I also drilled a .06 hole on the bottom of the plastic hose elbow so any moister will drain out of the hose.
ks
ks
