Here it is guys.. Gotta give BIG thanks to my bud David Buschur of Buschur Racing for getting me the hook up on it so fast! Hope to have it up and running as soon as tonight!:biggrin:
Sexy for sure! Looking foward to seeing what kinda power these make and what the spool up difference is vs. the GTQ.
That will make more power then anyone will ever beable to make imo. That in the DBB will truly be the last turbo any street car enthusiastwill ever need to buy.
Well worth the wait I guess.
How did the install go?
Can we see the beast installed?
Hi Kevin, I spoke to you and Bob S. together out at Norwalk. Here is a quick run down of the build. Car has made 2 back 2 back 10.06@138 with a GT70 P trim with a terrible 60 ft. I hoping this turbo gives it what it needs to be in the solid 9s.
DLS 249 in stroker
DLS/Champion GN1 ported heads
DLS ported intake
212/212 hyd roller
#95 injectors/Reds double pump
Cottons front mount
I have just added full stainless TA Headers, TA 3.5 dp, complete 3.5 exhaust. The car has a Janis built 2004r trans and AC converter. Full HR Parts suspension package.
I do not have a fast system(YET) and plan on doing this with with the stock ecm, chip and stock GM mass air flow unit. I know this is hurting the car plenty but I would like to lay down some nice numbers with this set up before moving on to a DFI.
The other thing that is killing the car to a point is Im doing this on 29x9 inch tires. This is a 17k mile original paint car with cold r12 a/c and I do not want to cut or roll the 1/4 panel lips to fit the 29x10s. I may end of having to regear to get 28x10s back under it if this becomes to much of an issue. Oh and of course it has no cage.
Brian
Cool, I remember talking to you now Sometimes my head gets focused on one thing at those races and I end up forgetting about all the people I talk to lol.
I was hoping you had a gtq on there to see some back to back comparisons. Looks like you changed quit a bit to get a fair side by side though.
Thanks for the install pics,
I ordered this one as well. Did you have to use an extended oil return line?
Currently I have a Turbonetics 72 on the car and MY steel braided return is stretched to the max.
Post up when you get to try it out.
We have very similar goals...solid nines. I want to get it done with less than 27PSI, so I can run 93 and methanol. Also I don't want to 60 anything less than a 1.45. So 140 MPH is my goal. BTW I am going to do this on stock stroke.
No prob man..lol You were still great to talk to and Bob is always a trip!
Nope no GTQ, I wish I had it. I might not of had to buy this turbo to achieve my goal if I had. I did have the 3.5 dp and exhaust since I have ran the car and didnt see any differance with that GT70 but not the TA headers. Those were just put on last week.
