black87buick
- Dec 27, 2009
As short story. I found coolant in the oil. No clear pressure build up or "pulsing" was found in the radiator with engine running at temperature and idling after a hard run. (NO I did not realize there was water in the oil until afterward). This was the same day I fixed the coolant leak from a weak radiator cap. Thus the hard run to make sure everything was sealed up. Glitter found in the oil filter - all new bearings and seals are on order and the engine is coming out.
The heads are bolted down with ARP HW and the gaskets are the stamped steel with industrial strength adhesive ( I am blanking on the source/brand it was a PITA to heat cycle the engine and re-torque following the process.) I blew both (crappy felpro) head gaskets before and wanted the best bullet proof gaskets....this was several years ago. I am confident the case of the coolant leak is not head gasket related. Only time will tell. I hate to rip the heads off.
Intake: Upon inspection of the engine following the discovery of water in the oil ( and a huge oil/water mess in the drive way) the rear intake valley rubber seal was blown out!
I removed the intake and found water on top the valley pan. So far evidence suggest the intake/valley pan is the source of the leak from the drive's side rear head port (top side between intake and gasket)
I do not know PN of the suspected failed valley pan. It does look like the new Mahle PN# MS15960 -> It is all blue. I am used to a steel non-coated valley pan. The picture of the Mahle reflected this online and in the store, but the actual part is blue coated with something.
QUESTION 1 : Is the MAHLE MS15960 a quality part?
Question #2 : Who sells an Internal Waste Gate Down pipe that fits the ATR/Kenne Bell Style headers.
Thanks,
-Chad
Thanks,
-Chad
