Originally posted by Spike Clapper
I have not yet received final approval from upper management to send our official post. I can tell you that we do have compatibility issues with our DIS Ignition Controls and aftermarket controllers. We have been working with the individuals from FAST and we do have a couple of Buick GN's coming into our manufacturing facility to do some additional testing.
Spike Clapper
Customer Service Manager
MSD Ignition
Originally posted by ijames
And has anyone noticed Pete Barton's post about the rev limiter switches - all down is not off, it's 6250 rpm. Is this the problem or what?
Originally posted by TurboDave
I may be way off base here, BUT
I can see where adding an aftermarket ECU such as FAST would not have any rev limit issues.
However, when using the MSD DIS4 with the stock ECU, I'm thinking no matter what is done with the MSD, the stock ECU's chip controlled rev limiter is going to take over at it's set point.
I'm at work and can't look into the file here, but if memory serves, even if one was to set the rev limiter to it's highest HEX value (FF), I think that still equates to a maximum value of 6250.
Correct?
Originally posted by EightSecV6
I can Honestly say after using all types of MSDs on all types of systems, NOTING can outperform the analog pieces!!!!
