hey guys..took car to track this weekend and it ran slower each pass...scratching my head. please help. mods are below...
206 cam, mild port on heads, intake, RJC plate, new valve springs, etc..., ATR SS headers, 3" exhaust, stock lock up converter, TT chip set for 93 octane, 19/17 on the timing and at 16lbs boost. stock rear, turbo, intercooler. 60# injectors, hot wire kit to fuelpump....so pretty mild to stock car. i have ran a best of 8.34 on 93 octane and not touching the chip adjustments. 1.80 60ft. that was a few weeks ago. now to this weekend......
55 deg weather in KY, so good cool air for power.
27x10.5 hoosier quick time pro's, stock T-type wheels.
put race gas in, left boost at 16 lbs, bumped timing up to 23/21 since i had good fuel and it ran first pass there after driving for an hour 8.29 @ 82.6 mph. with a 1.83 60ft. so not to bad...i didnt think. taking off about 5lbs boost. zero knock.
So i got frisky and turned boost up to 18lbs. left everything else alone. ran it twice that way and best was a 8.38 @ 82.4 mph, with a1.93 60ft. i was leaving at 8-9lbs of boost, didnt feel like it was spinning, but who knows...still slowed down 60ft. and mph and et. so i was like what the????
still no knock i was like what the hey..so i turned it up to 19 1/2 lbs boost, timing left alone at 23/21 and ran it, same deal, 1.90ish 60ft. and same mph as before...zero knock. car felt good just times sucked and seemed to get slower. so i took some fuel out of 1st and 2cnd gear -3% i think, to try and help 60ft. times...and it ran worse. zero knock but ran like a 8.40ish...at 81mphish... i gave up and drove home. now frustrated....
i did pull a couple of plugs today just curious, and they are autolite's R43TS's gapped at .040 didnt look all that great but didnt look terrible either.
is my plugs gapped wrong or wrong heat range for that fuel and boost?
is my converter going bad? trans? where and why do i seem to be losing power? if it was spinning wouldn't my mph still go up with more boost? but taking off at 8-9lbs of boost i think it hooking o.k. just not feeling its best.
help......???? ideas?
