unboostedV6
- May 25, 2001
The mixture distribution became more even among all cylinders when the secondaries opened. The rear cylinders fattened up as the fronts probably leaned out a little. You took 4 jet #'s out of the primaries...take the same 4#'s out of the secondaries, too. That cam is good for a power peak around 73-7400 rpm and a torque peak around 55-5700rpm on a 13.5:1 engine. I think it'll have to rev higher before you see the peaks w/ 10.8:1. I shift my 266-266, .640" cammed engine at 8000 and currently make around 380 rear wheel hp. Pull some timing out...try 32 deg total. 36 seems a bit much for pump gas.
Don, his link from the first page works.
Greg
Greg
