buickstage II
- Jan 24, 2005
I have a 275cu.i off center in Australia and im looking at making the maximum amount of horsepower as possible, ive made 242hp at the wheels and that was only at 6000rpm as the power just drops off on the dyno, would love to have anyones help thats made good power n/a, using 98 octane (may look into race fuel if the benefits are there)
stage II (016) 4.015"
3.625 moldex
6.5 carillos
je 10.8:1
je moly rings
stage II heads jessel rocker
reed roller cam 106 lobe sep, 308/312 adv, 267/274 @ 0.050", 0.667" lift at the valve, intake centerline at 102
balanced to 38 percent
milodon gear drive
ceramic coated extractors 36" long, 1 3/4" into 1 7/8", 3" collector to 2 1/2" merge with single 3" pipe to the back
750 holley hp vac sec
msd 6al, distributor, 18 degrees initial and 36 total @ 4500rpm
sce gaskets
victor junior manifold
moroso 4 stage dry sump, currently running crank case under about 10 in.hg
power glide
3000 stall converter (unknown condition)
9" diff with 3.25, full spool
15 X 10 convo pros
any help, advice or criticism appreciated!
cheers Simon
last but not least a really big thanks to Mike Booher for all his time and help to get this motor together, it would have been extremely hard without him, not to mention all the parts he has freighted here to Australia!
Thanks Simon
3.625 moldex
6.5 carillos
je 10.8:1
je moly rings
milodon gear drive
sce gaskets
power glide
15 X 10 convo pros
cheers Simon
Thanks Simon
