Lots of parts for sale
gnpoweredrail
All these 86-87 parts are off a low mile(40,600) car that the engine was pulled in 89-90 and wrapped in plastic.
86-87 exhaust manifolds with no cracks and all heat sheilds there. $150 plus shipping.
86-87 stock IC with shroud. bottom of shroud is cracked but repairable and all there. $100 plus shipping.
86-87 IC fan and hub for crank pulley.no cracks and in perfect shape. $45 plus shipping.
86-87 stock turbo cover with turbo bracket.needs repainted has 40,600 miles written on side of it. $85 plus shipping.
86-87 stock oil cooler lines. $25 plus shipping
86-87 a/c manifold hose set. $25 plus shipping.
86-87 ac compressor that came off the wrapped engine with hoses on it.hoses not included(see above) $50 plus shipping.
86-87 stock up pipe(I believe.might be turbo to IC) with no dents with coupler $25 plus shipping will through in a factory turbo to MAF hose.
86-87 engine mounts(these came on a another engine I bought not the one wrapped since 89) $20 plus shipping.
86-87 stock exhaust elbow. $35 plus shipping.
86-87 breather pipe from turbo to right valve cover $5 plus shipping.
55lbs low imp injectors with a fullthrottle speed 100 octane chip and a 16 position Caspers Ultrachip thumbwheel havent been run in a while.the 100 octane chip is new never used $350 plus shipping.
60lbs FAST low imp injectors in awesome shape. $250 plus shipping.
These are my hot air parts that have been sitting in a shed since the late 80's early 90's
84-85 turbo/throttle body assy with brackets,TPS,vacuum block,oil drain tube,exhaust elbow/flange and wastegate act.Still has the flange adapter for the turbo inlet. Has been off a car for a very long time.turbo doesnt spin but no exterior damage $100 plus shipping.
84-85 turbo regal engine and front lamp harness(I think).this was in the box with all my other hot air stuff.Looks like a hotair harness and lamp harness.Its old and would need work to use this only with no other wiring with it but if you only needed some pieces off of it this would be a good part for you. $25 plus shipping.
84-85 intake in really good shape.even has the o-ring were the turbo slides on and the oil drain.EGR tube there also. $40 plus shipping.
84-85 factory exhaust manifolds in ok shape,drivers side has usual crack but is repairable as it hasnt been touched yet.They look really good. $45 plus shipping for the pair.
84-85 exh manifold to turbo pipe in great shape $40 plus shipping
84-85 t-stat housing in very good shape $30 plus shipping
84-85 fuel rail with stock injectors,injector harness and fuel pressure regulator. missing 1 injector $40 plus shipping.
Also have some carb parts.2 compressor housings and 2 carb intake/mount the part that bolts to the compressor and to the bottom of the carb and a brand new 3 hole intake(from compressor to intake on engine)
Take it all for $45 plus shipping.
Probably have more that I am forgetting.
working on pics and will post them here when soon as I get them.
Prices are OBO and will use USPS mostly for shipping unless its a big box then it will be UPS or Fed Ex.
Thanks for looking
I will take these pending pics to 9secondv6@centurytel.net
Bryan
Here ya go
Bryan
pics sent and here they are for everyone else
Thanks for the pics, please give me a price shipped to 63366.
Bryan
Bryan
I will find a box at work tuesday for the lines.There is so much hard line its going to be a decent size box.The compressor will be easy.
I will try and find a box I can get them both in and I will secure them so they wont get damaged.
Looks like 2 different set ups. Can you give me the part numbers of the parts please? I am interested in them but I need to know what they're off of.
the one with the 3 studs for the carb and the whole coolant vacuum sensor is 1261692 with a date of 1-12-78.
The other is 1258703 with no date.
The compressor houisngs are the same with no numbers except one says M11 after air research and the other doesnt.
I got a box at work today that will work with some modification.
I will get them boxed up and weighed and get you a price.
Thanks for your patience.
I have to hold off on selling the lines as trying to find a box is a huge pain in the ass.
I will get one though it will just take a while to find one that will work.
