Originally posted by xlr8ngn
Neal, thank you very much for the information. You are in the stage arena. Are your times with a stock block or with a stage motor? 9's is FAST!!!! I did not read your signature the first post.
The motor that is now in the car is a Stage II with GN1R heads.
This is the motor that has run the 9.71's, as I wrote a few posts
above my 3.8 ran 10.76's this was with ported and polished stock iron heads, stock crank, JE pistons a Conleys 221/221 flat tappit cam, stock rods, 55# injectors and a TE-63-1 blueprinted and balanced by Conleys. The IC was a stretched stock with the bigger neck and a cold box on the upper half of the IC the bottom was open to the air. This motor would run the 10.76 at 22# of boost with a 7# launch. The cars weight was 3780 with me and had no fiberglass anywhere.
If I were to go play on the street I would take an ice chest full of ice to load the IC. As far as playing from light to light the car was fast enough to raise hell with most of what you will see on the street with out putting more ice in the IC.
The problem with playing on the street at this level became traction, even with cheater slicks (dot soft compound) was that if the street was dusty or not clean and I could soft launch it the car would go up in smoke when it shifted into second like a John
Force burn out. I'm sure the suspension could be set up to be a real street racer but that set up usualy is not best for the track and that is how the car rolled over from a real street driver to more a toy and drag car, but it still has all the options it came with.
If you go to Precision Turbo & Eng web site there is a picture of the car making a launch, this was with the 3.8 motor and was at
the Noble, OK Buick - Ford Shootout a few years ago. You can look at the rear tires and see where with this amount of power where good traction serfice is important.
Take Care and good luck
