Originally posted by Unsafe6
Do I have to run nines to use lighter aftermarket wheels too? I need rotors and if I can save some weight why not?
It has to do with how brakes work.
When the pad is pressed against the rotor, it produces heat. That heat has to go somewhere or the pads will burn up and your fluid will boil. That somewhere is the rotor. The more mass, the more heat it can absorb before the system fails.
On a car this heavy, going as fast as yours, you want big, nasty, heavy honkin' rotors. Cut unsprung weight anywhere you want, but you want the biggest rotors you can get.
Now, this doesn't mean you can't save weight somewhere else, like the hub. If you can get a two-piece rotor/hub assembly with a billet aluminum hub and an iron rotor (the Wilwood and Baer brake kits use this), you can save a lot of weight, and still get a nice, heavy iron rotor.
Lightweight rotors are sold by lots of companies, but if the car is street driven, you shouldn't use them. They can only take 1 hard stop, then you have to let them sit and cool off.
