tfoster209
- Jun 3, 2013
I just installed a new turbo and the car started smoking huge clouds of blueish white smoke after a few minutes of idling. After checking for possible oil leaks I found what appears to be oil coming out of the oil into the downpipe. I did not find oil any where else : spark plugs, up pipe, throttle body or inter cooler. Oil return line appeared to be kind of bound up so I straightened it out and still have the same problem. I ran the car a few seconds without the oil feed line. Car did not smoke. But all the oil shot out in a matter of seconds. Oil pressure is around 80 on startup and goes down to around 60 when it warms up. Could the oil pressure be to high? Should I run a rescrictor on the oil feed line? Can there be an issue with the oil return line? Any help or advice will be appreciated. Thanks in advance.
