bmackinnon
- Feb 24, 2005
OOOO i dont wanna make another thread, what temp should my car be at normally? After driving a little my scanmaster said my car was around 214-215 is that normal or is it about to catch on fire and explode??? Thanks
That's pretty hot! Are you sure the fan is coming on? Alot of people run a 160 thermostat..... I run a 180 and the car runs 180-190... I believe the tiny loss in performance running at 180 vs. 160 is well worth it, as the engine components/clearances are designed to run at the higher temp, and the oil runs hotter, allowing it to vaporize/burn off moisture/contaminants... kinda' like the idea that it's bad to always run your car only for short trips that don't allow the oil to reach full operating temp... and your owners manual will specify that as 'severe' duty.... plenty of intelligent thought on the subject if you search....
but anyway... 214-215 is hot..... definitely don't want to be any hotter than that... the tt chip should turn the fan on around 165 I think.... is your's working correctly?
