huntsg
- Aug 10, 2009
I recently installed my new scanmaster 2.1. I ran two WOT passes on February 16th and here are the results of the last pass.
O2 mV 289
Knock retard 16.6
Since I was running so lean I added a boost gauge, an O2 sensor, a MAF sensor, a Hotwire kit and an XP-Plus Fuel Pump. I did one pass and my O2 mV have come up to 722 but my Kr was still 16.5. This week I added 42.5 lbs injectors with matching 93 chip and a fuel pressure regulator. and here are the results:
O2 mV 781 WOT
Kr 14.8 WOT
At hot Idle:
O2 mV 100-750
Kr 0.0
AF 05
L8 32
Bat 13.9
Int130
BL 122
CLt 182
AtS 81
r 825-925
tps .46
IAC 44
cc 02-252
MAL 00
The car runs smooth with plenty of power and no misfires. I checked and found no vacuum leaks. I have a stock turbo and the boost was about 17 lbs. I set Fuel pressure at idle at 46 lbs (I don't have a gauge installed permanently). Any suggestions on what to look for next? I am at a loss... Thanks.
O2 mV 289
Knock retard 16.6
O2 mV 781 WOT
Kr 14.8 WOT
At hot Idle:
O2 mV 100-750
Kr 0.0
AF 05
L8 32
Bat 13.9
Int130
BL 122
CLt 182
AtS 81
r 825-925
tps .46
IAC 44
cc 02-252
MAL 00
