MONSTER GN
- Dec 22, 2008
I have an 87, and my turbo doesn't seem to spool real well until about 3,000 rpm, this may be a separate issue but, when im boosting and its pulling I can see on my lil knock gauge the knock is creeping up, and today I heard some popping in the engine bay area when it did this, still seems to run ok, im just wondering what can cause this? I have a factory build minus the cam, and I have a turbo tweak chip to compensate for that cam. What can cause this issue? I have a new 255LPH Pump in there with the hot wire kit, so the fuel pressure should still be good. This problem was still here even when I put this pump in and the PSI was raising 1:1.
What can cause this issue? im almost at my witts end with this thing, I also feel like it doesn't boost like it really should I feel like the car should have a lot more than it does. It runs and drives great just doesn't seem to want to boost and when it does under heavy boost this problem occurs. Any input would be greatly appreciated
