The factory fan runs off the engine so it eats power and takes up space in the engine compartment. An electric fan doesn't eat power, and is slimmer making it easier to work on the car.Wouldn't it make sense to leave the factory fan in place or does it cool fine without?
sorry I re edited my post......I know the benefits my ipad just messed up lol. I ment fan shroud for better air flow with the electric fanThe factory fan runs off the engine so it eats power and takes up space in the engine compartment. An electric fan doesn't eat power, and is slimmer making it easier to work on the car.
I do not know if the 86/87 fan will bolt on but I'd like to know.
I have the fbody radiator and my tranny lines reached just fine, my hoses also did, the radiator bolted right in, it was a little right though but now the car runs a lot cooler.
I'm using a ford Taurus Efan ....I just drilled 2 holes for mine but I also kept the stock shoud.a little trimming on shroudIs there a certain electric fan setup from another vehicle that will fit in place with very little modification?
What year ford taurus(tortoise)?I'm using a ford Taurus Efan ....I just drilled 2 holes for mine but I also kept the stock shoud.a little trimming on shroud View attachment 207849
Can't quite remember but I think it's for a 97......people use them a lot on s10 trucks if that helps with the search....mine came off my s10What year ford taurus(tortoise)?
View attachment 208487This is my setup. 77 chevy Monte Carlo 3 core radiator & flex a lite fans. I wanna try the Ramchargers fan setup but I mocked them up last week & they're like 1/8 of an inch to big for the cu1037 radiator. I want both coolers on the radiator so my options are limited.
I have the dual ramcharger fans and had to grind off the 1/8 inch from the sides of the fans so that they would fit.
Brad
I got a RAMCHARGERs also and I was wondering what is the best way to wire up the dual fans? Summit had a dual relay fan kit for $67.00? Caspers and Racetronix both have kits?
