in my '87 GN, at WOT the car is fine, the boost is only set to 10 psi right now.. at part throttle up around 3k rpm you can start to feel it lose power and almost start sptutering..
the coil i am using has checked good with my meter at least..it ran good in my other gn..
I just put MSD super conductor 8 mm wires on and brand new CR43TS plugs in it, hoping that would solve the problem. if not, what else could cause that? I have a TE 62 turbo, 868's (JL 868 93 octane chip in it) and the stock intercooler/downpipe/hollow cat/stock exhaust. K&N filter
the other plugs were autolite 25's - they looked good, not too lean or not too rich.
