I bought an Alpine MRD-M301 amp and 1 Audiobahn 10" AW1000Q dual voice coil sub.
If it matters, this is on an 04 Monte Carlo and not a Buick.
All stock stereo except the new amp and sub.
A buddy came over and we just finished getting everything hooked up, turned the power on, and the sub just cracks and pops.
He triple-checked where he tapped into the factory amp that's mounted in the trunk for the RCA/speaker level input. He's pretty sure he's got all the wiring right.
The wiring from the amp to the sub is right, and tomorrow I'm going to pull the sub back out of the box and check the wiring from the terminal on the box to the sub.
Since it's a dual voice coil sub and a single channel amp, I ran the positive and negative out of the amp to the positive and negative on the terminal on the sub box.
Then inside the box, ran the positive to 1 of the positives on the sub and the negative to 1 of the negatives on the sub.
Than ran a wire from one positive to the other positive, and from one negative to the other negative. That should get me the 2 ohm load I'm seeking right?
What should I start checking tomorrow to see what's wrong with this sub?
Is it possible the sub is blown, even though it's brand new and has seen very little power?
