Need some help figuring out if the VE Tables (or what else) will have anything to do with the injector duty cycle being maxed out.
Senario: 96lb injectors showing 100% +/- 3% between 4500-5700 rpm (top of 3rd gear). VE numbers are around 94 in that same range and there is O2% correction of approx +25%. Actual A/F is right around the 11.5 ratio. Fuel pressure was holding steady for the boost being run, but we have not yet verified if the 2nd fuel pump is coming on as it should. Any help you can extend to this would be helpful and appreciated. Thanks.
Regards,
Shev.
Regards,
Shev.
