Guys,
Now that I have my timing correct finally. I wanted to verify that the ICC is working properly so I set the base timing at 36 degrees
across the map and then went in and retarted #1 by 10 degrees. I understand that it does not correct below 2000RPM so we reved the motor to 4500rpm and still no correction. I was expecting to see the timing light value change by 10 degrees. Whats Up?
Thanks,
Doug
Thanks,
Doug
