Howe ported heads
87-TURBO-T
Anybody know anything about flow numbers or performance of these heads? Years back Bill Anderson said these were one of the best flowing heads out there. Thanks
My heads are done my Howe and have flow numbers. basically something like 310 on the intake and 265 on the exhaust with 2.08/1.6 valves.
AG
Lift 200 250 300 350 400 450 500 550 600 650 700 750 800
Flow IN. 150 195 217 245 259 278 290 300 305 308 310 310 310
Flow EX. 130 181 197 219 229 251 255 259 261 263 264 269 269
They also have a unique looking rocker set up.
Honda/Acura engine performance book next to Buick aluminum performance heads :confused::jawdrop:
Now that there is a sight not to see!!!!!!:ROFLMAO:
I was waiting for someone to notice that!!!! In all honesty it was in a box of old hot rod mags I bought at a yard sale.
Chris Howe ported my heads as well and they have epoxy in the bottom of the runners as well. The "roof was raised" on the intake and heads to get a more direct flow to the valves. Chris was doing heads for Jon Kasse down in GA. Engine Master winner and gigantic big block builder several years in a row.
I'll second that. Steep valve angles generally require tall ports to help the short side and promote tumble. I'm sure he did it on purpose. Chris has been doing work with Kasse in recent years. My ASA take-offs were done by him for Wegner's shop in the early early '90's. I have contact info if you want to pm me.
GB
Question for unboosted, how much hp are you making with that combo?
No where near what it should ... 11.50's at 3250lbs. New cam grinder says it's losing 75-100 hp out the exhaust from excessive overlap. Shooting for 10.80's in July heat.
GB
GB
Your running this on alky? If so i would say you don;t have enough compression or rpm (8000+)..it should be like 14.5:1...these heads need some squeeze to make them work..
