Here's what I saved from some others posts over the years:
It really doesn't have much tension on it. About 1/2 rev is all it is wound. Just pay attention to it's and the throttle arm's orientation before you disassemble. Pry back the two lock washer tabs, loosen the nut, pull the linkage arm off and the spring and plastic bushing will follow. Carefully remove the two screws holding the blade in (they are "staked" in back, so can be a little tough to get started) and pull the blade out. Remove the screw that holds the shaft clip on and carefully slide the shaft out to that side. Sometimes there are burrs around the screw holes on the shaft that won't allow it to slide out through the casting. Simply knock them down with a small file till you can easily slide it out. If you force it, you will gouge the casting. The stock seals will pop out with a screwdriver. Clean it up well, and you are ready to drive in the new seals.
Do you have new seals? They can NOT be found at the local hardware store... trust me. I get mine from MeasePerformance and he gets his from the original OEM supplier, but only after buying a large enough quantity that they would produce them for him again. I searched far and wide and never came up with a reasonable replacement till Keith and I exchanged info.
Should you need any shoot me an email. Good Luck!
__________________
Jay Jackson (the 62MM TB guy!)
Throttlebodys.Com does repairs now (Stevemon)
Untitled Document has parts
Im in Georgia so i called Harwal they directed me to Applied Industries in Macon Ga. phone#1-478-784-7165 guy named carl.... if youre talkin about the same bushings or seals as i was told theyre called maybe the same i dont know -the part that the shaft rides on. Any way they took my name, address ,card # the part # i ordered for the buick is 10x17x05B.... i ordered 4 , for all 4 counting shipping they were $30 total.. came in 4 days if i remember correctly.
10 x 17 x 05B NBR
I was able to get them right from Harwal. I ordered about 8 pairs to take care of the gals and guys in the local TB club.
replacement seals for Throttle body shaft.
I found a great source for these seals, most turbo buicks need these seals replaced by now, they cake and crack over time leading to leaks you cant detect but hear them, these two seals sit on each side of the throttle body shaft, and are about the size of a dime, GM wont sell you these seals alone, they want to sell you the whole Throttle body which cost about an arm and a leg from them i found a great source for these seals, and trust me guys they need to be replaced if your car has more than 30k miles on it, the seal model and size are as follow, all metric size.
17x10x5B, the B at the end is the model of the seal if dont mention it you will get the wrong ones, you can get them from this supplier which is located in VA.
Untitled Document
Harwal Inc.
P O Box 363
72 Industrial Lane
Barre, VT 05641
Phone: (802)223-0197.
just thought i share with everyone.
they run about $7.00 dollars each and there is no need to do mickey mouse work with these they are correct size and perfect fit.
Hope that helps! It's always good to save old posts
John
