how much alk
dadmomcat
Just install the SMC dual nozzel set up, I'm still trying to fine tune the set-up and used one bottle of 100% alk in two days. I would think it would last alittle longer.
I'm trying the mix of water to alk. It seems that 50% of each is the way to go.
Thanks for any input here
Fine tuning means a lot of WOT blasts.
Uses lots of alky., tires too. :D
On the street in the summer one bottle lasts me a full week of daily driving.
In the winter even longer. ;)
you will prolly end up with a 70% mixture with that set-up. 50-50 happens with a smaller nozzle, and 2 stage set-up. I don't think you would gdo much better than using full opump speed, and 100% de-natured with that set-up. In fact you might find that 75% pump speed works the best. Finding out what works best means taking it to the track.
Remember that you can actually loose power, even though the boost guage is higher, due to drowning the spark a little bit.
THANKS Turbo_Tim
Have to find the best setting with trail and error. Going to the track will give you test results on et and mph.
