Toby_Goodmk
Test Fit officianto
- Dec 9, 2011
Someone tell me this is normal to see this type of damage during an engine break in. The bearings look to show not only severe oil contamination but also looks to be an oil starvation probably due to crap in the feed holes. Because of the bearings failure I'd say it took out the thrust bearing then heated the compressor and turbine shaft all to hell. Keep in mind this is only 200 miles of break in. I tossed the oil at 10 miles (5 hrs run time) and now will do it for the 3rd time. I am running the canton oil filter with the turbo saver by TR Custom Parts. If its a turbo saver, I would hate to see the condition of the turbo without a turbo saver.
Thank God this is my break in turbo being used as recommended by the turbo builder. This turbo had new bearings at engine break in and was freshened. It was nice and tight, now its sloppy and let oil pass by
