mikestertwo
- Sep 13, 2006
I have had 4 different cars come in with stock MAF failures and each time it was because the person put the MAF in backwards. My son also had this problem when he removed the MAF to do some work on the car and when he reinstalled it, he put it in backwards. Took the car out for about 15 minutes and like you said ran pig rich. Discovered the problem, turned the MAF around and the car still ran pig rich. Looked inside, and the strain gauge was black and wrinkled. This was the same symptom on the other cars, reversing the MAF and the strain gauge appeared to overheat. I have never seen this kind of problem with the LT1 style mafs. Reversing them seemed to have no ill effect on the maf. Now, this failure happening once with a maf could have just been a fluke, twice maybe, but I believe in cause and effect. I have seen this happen 5 times in the last 10 years and each time the failure was right after the MAF was reversed. If the reverse flow wasn't the cause of the failures, enlighten me, I'm open minded and willing to learn.
