Hopped in the buick to go for a drive. Everything was fine, car was running great. Went to hop on the freeway... It pulled fine onto the freeway, but when I was merging I had to let off the gas to slip inbetween cars. I went to pass the car infront of me and.......
put put put... fart... put put. faaaaaaarrrrrrrrrtttttttt
I took the next exit, barly able to keep 60 mph.... and limped it back to the shop. It bucks, and farts under load and no load. Sounds like ignition is cutting out. Here are all the things I have tried.
Unplugged and Drove:
Cam sensor
Air flow
Coolant
Egr Solenoid
All at once
Same thing every time.
44 psi fuel at idle.
Swapped ignition module and coils with another good (actually... great) running car. - Same thing
Swapped ECM's - same thing
Swapped with same chip off another ECM- same thing
The thing runs PIG rich, and when I whomp on it, and it bucks, it shoots fire out the tail pipes... kinda cool, but not really.
I guess tomorrow at work Ill hook the crank sensor up to the lab scope and check it out. But it seriously just happened all at once. One second everything was running tits... the next....
If anyone can think of ANYTHING else, input is greatly appreciated. But im kinda figuring its going to be the crank sensor. I figure even if that is what it is, mabye this post will help someone else in the future to figure out the problem their car is having.... I guess we'll see.....
Cam sensor
Air flow
Coolant
Egr Solenoid
All at once
