Does anyone know were to get a new belt tensioner? I can't find any at the parts store and NOS4GN does not have them.
Yea I just read the thread, heard about it but didn't see it till just now..it was a limited run. idk if theyre doing another run
I believe the ears breaking off is the most common issue, but getting tired is also bound to happen. They are almost 30 years old. As for rebuilding, the way the alum is swedged over the metal plate to keep it together...it would be hard to rebuild it...without making it look modified.Other than having a spare, what goes wrong with these tensioners?
I wonder if they are rebuildable if the spring gets tired or something like that.
also, how i can check it, other than the obvious bearing failure?
Just to clarify....from what I've read, the ear breaks where the bolt goes thru it that holds the alternator. So if you change the alternator don't over tighten that bolt!I believe the ears breaking off is the most common issue, but getting tired is also bound to happen. They are almost 30 years old. As for rebuilding, the way the alum is swedged over the metal plate to keep it together...it would be hard to rebuild it...without making it look modified.
The billet ones are really very very nice, but a small fortune. They would be rebuildable though...so they would be a one time purchase unless the ears breaking become an issue on them also.
