I've been chasing high idle BLMs and did the rubber glove trick (boy, that doesn't sound right) on my car. BLMs went down to 116, so I was pretty sure that it was a leak off the vac block. I found a couple, sealed them up, and took the car out for a spin.
The BLMs are even worse! The PCV line was one the problems, so I'll have to test it again, but I'm trying to read the other BLM cells. If I understand this page Block Learn Multiplier and Integrator correctly, then
CELL 0 = unmetered air @ idle causing ECM to dump fuel in
CELL 1 = ECM pulling out the fuel added in CELL 0
but I don't get why CELLS 9 & 10 are showing so lean when the rest are close. What else am I missing? I could post the whole log later if that helps.
Thanks in advance!
Thanks in advance!
