mongoose87
mongoose87
- Apr 12, 2008
Please I need help, My 87 GN will hesitate every time I put it in drive and try to accelerate. I will backfire like crazy, and smokes blue, wideband will read rich to lean rich to lean about 5 times then shut off. I had it checked at Firestone and they tried but no luck!!!
What I have done:
New: 2 Coil packs both working
New: Coil module also working
New: MAF and I also have MAF translator New
New: Wires and Plugs
New: MAP sensor
New: Crank Sensor
New: TPS Sensor
New: IAC Sensor
New:Fuel Pump ( Aeromotive stealth)
Hot wire kit was new 7 years old
Volt booster 7 years old
New: 42 lbs injectors with Turbo Tweak chip
49 TA turbo
100lbs Valve springs about 2 years old
Please please help!!!!!!!1
What I have done:
New: MAP sensor
New: Crank Sensor
New: TPS Sensor
New: IAC Sensor
49 TA turbo
