Might as well get Cometic head gaskets and just be done with it....
Cometic Gasket, Inc.
Are you doing your own porting? I've been working on a set, haven't finished them yet. Here are some before and afters. Just make sure you take your time if you do your own work....
Felpro 9441PT
Advance Auto Parts: Head Gasket by Felpro - Part 9441PT
ARP hardware
ARP HEAD BOLTS - Turbo Trans Am Forum
Joe
Just an FYI.. one thing Champion does is install hardened seats. This helps the head from cracking between the valves which is very common due to the water design on them in that area.
I have it at a shop here in Jax, the owner evaluated it himself. They have other turbo cars there that are GM products. He did a compress test and did some kind of other test to tell me about the block. I know the heads are still on the car. I just took it over there today and I got the news just a few minutes ago.
Typically if you pop the HG it wont have compression. #4 is not the typical cylinder that goes. Typically its #3 on the drivers side.
You must of detonated the daylights out of the motor to create enough damage to require a rebuild. I popped many a head gasket on a TTA.. never needed anything but a gasket. My worse one happened with Cometic gaskets and it tore up a piston. I installed a new piston and back on the road it went.
Blocks are tough on the cars. As are the pistons.
This is why I say pull heads and post pixs. If your at the mercy of a shop.. you may want to get a second opinion.
FWIW.. TTA pistons are different than GN pistons. Doing a rebuild can be pandoras box.
I have a used set of OEM TTA pistons if you need them.
