Need some help diagnosing a coolant leak in the passenger side between the block and head. I can see coolant dripping from the tab of the head gasket. Obviously my first guess would be the head gasket, but compression is consistent with all other cylinders around 165. Looking through the receipts given to me by the previous owner, I see it has felpro loc wire 1007 head gaskets, so that rings a bell that he told me the heads were o-ringed. So I guess my question is whether this is actually a head gasket leak or something else. Is there a good way to check? Could the outer head bolts be loose? They are ARPs. Is there an easy way to get to them to re torque? What should the torque be?
Thanks guys. I know that's a lot of questions. I had actually put the car up for sale but am reconsidering if this looks like it will be an easy fix.
